Pagine: 1 [2]   Vai Giù
Stampa
Autore Topic: Problemi con la scheda M-Audio Delta 66, l'audio frigge.  (Letto 1144 volte)
0 Utenti e 2 Visitatori stanno guardando questo topic.
Maurizio Burato
http://www.mbradio.it
Amministratore
Super Utente
Offline Offline
« Risposta #15 il: Lunedì 12 Settembre 2011, 18:10 »
Fonte M-AUDIO:
Applies to: Delta 44, 66 (OmniStudio), 410, 1010, 1010lt, Audiophile 24/96 & 192 devices.
Operating Systems Supported:
(32-Bit) XP SP3, Vista SP2, Windows 7
(64-Bit) Vista SP2, Windows 7
Our latest Windows Delta driver release (Installer Package 6.0.5 with Driver 5.10.00.5076) was posted to solve a compatibility problem with newer series motherboard chipset and CPU combinations from Intel. The problem identified was a low level distorted audio occuring with Core2Duo and i-Series processors. The sound in question resembled bacon sizzling while. Despite this one fix, we here in the Test and Customer Support groups stressed pretty heavily over whether or not to release this driver to full release knowing that there are other outstanding issues with the driver.
We felt that the severity of the issue was great enough to push this to full release for those users wishing to use the card in newer system configurations. The outstanding issues already identified by our customers are still being considered for possible future releases.
We encourage you to download and use this new driver and continue to provide us feedback on your experiences with this driver over the previous releases.
Loggato
Pagine: 1 [2]   Vai Su
Stampa
Salta a:
