Pagine: [1]   Vai Giù
Stampa
Autore Topic: Cryptobox Problem  (Letto 1258 volte)
fabianpravisan
Nuovo Utente
Offline Offline
« il: Giovedì 25 Febbraio 2010, 20:25 »
Hi Maurizio and forum people´s
Have a problem with cryptobox (usb). when cut the light or restart the pc the mb soft start in demo mode, is like no recognize the present cryptox, its always happend, the solutions is restart the mb soft or out the crypto and in again.
Any other solution?
My OS is windows 7, but have same problem in Xp Sp2
Fabian
Loggato
Maurizio Burato
http://www.mbradio.it
Amministratore
Super Utente
Offline Offline
« Risposta #1 il: Venerdì 26 Febbraio 2010, 15:11 »
Have you installed the original drivers from www.marx.com?
You can donwload it from here:
http://www.marx.com/ftp/pub/software/CRYPTO-BOX/SmarxOS/windows/CBUSetup.zip
First uninstall the current driver, then install it.
during uninstall and install driver, MB STUDIO must not be running.
Loggato
Pagine: [1]   Vai Su
Stampa
Salta a:
