Pagine: [1]   Vai Giù
Stampa
Autore Topic: Streming MB Studio  (Letto 1376 volte)
Medeiros
Utente Full
Offline Offline
MB STUDIO User
« il: Martedì 13 Aprile 2010, 00:39 »
Maurizio I am to use streming in the MBStudio and for times it appears the window of the DOWS and appears this information in log.
Because this appears and as I make not to appear?
* PROB.JPG (145.93 KB, 1024x768 - visto 163 volte.)
* 12_Abril_2010.txt (1.58 KB - scaricato 87 volte.)
* 12_Abril_2010_Encoder1_Ping.txt (0.6 KB - scaricato 77 volte.)
* 12_Abril_2010_Encoder1_Tracert.txt (0.56 KB - scaricato 77 volte.)
Loggato
Rádio Sines - Portugal ( www.radiosines.com )
Maurizio Burato
http://www.mbradio.it
Amministratore
Super Utente
Offline Offline
« Risposta #1 il: Martedì 13 Aprile 2010, 02:01 »
In Configuration\WebCast\More you have this option enabled "In case of failure network test", so MB STUDIO run the dos commands "ping" and "tracert" to test if your destinations are reachable (while ping and tracert are running you'll see black dos windows for few seconds).
In the folder LogWebCast you'll find the results of ping and tracert; here you'll find help to understanding the problems of your network.
As you can see, at 20:26:28 you was experiencing a packet loss problem:
A rastrear a rota para apollo.redelx.com [77.91.203.179] at‚ um m ximo de 30 saltos:
  1    <1 ms    <1 ms    <1 ms  192.168.1.1
  2   698 ms   629 ms     *     10.5.0.1
  3   705 ms     *      838 ms  pa1-84-91-0-89.netvisao.pt [84.91.0.89]
  4     *        *        *     O pedido excedeu o tempo.
  5     *      982 ms     *     apollo.redelx.com [77.91.203.179]
  6   462 ms   471 ms   486 ms  apollo.redelx.com [77.91.203.179]
Rastreio conclu¡do.
« Ultima modifica: Martedì 13 Aprile 2010, 02:03 da Maurizio Burato » Loggato
Medeiros
Utente Full
Offline Offline
MB STUDIO User
« Risposta #2 il: Martedì 13 Aprile 2010, 11:54 »
Not to appear black dos windows for few seconds disablbe option "In case of failure network test"?
« Ultima modifica: Martedì 13 Aprile 2010, 11:56 da Medeiros » Loggato
Maurizio Burato
Amministratore
Super Utente
Offline Offline
« Risposta #3 il: Martedì 13 Aprile 2010, 12:17 »
If you disable that option you'll never see black windows, but also you'll never get the ping and tracert file reports, so, in case of network problems, you'll never know where is the problem ... it's your choice.
Loggato
Medeiros
Utente Full
Offline Offline
MB STUDIO User
« Risposta #4 il: Martedì 13 Aprile 2010, 12:43 »
Maurizio thanks!!
Loggato
Pagine: [1]   Vai Su
Stampa
Salta a:
