The latest NVIDIA graphics card drivers cause a serious leak of resources which after hours or days of uninterrupted operation can cause MB STUDIO and/or other applications to crash. The number of handles continues to grow. To find out if you are affected by this problem, look at the resource indicator located on the MB STUDIO main screen:
If the number of H: handles keeps increasing over time exceeding 10,000 after hours or days, if you are using the video plugin, if your computer has an NVIDIA graphics card, then the problem is probably caused by the NVIDIA driver.
To fix the problem simply install the latest stable driver (522.30 studio driver) which is here: https://international.download.nvidia.com/Windows/522.30/522.30-desktop-win10-win11-64bit-international-nsd-dch-whql.exe
Also, during the installation, be careful to choose "graphics driver only" (do not install GeForce Experience at all!)
after restarting windows the problem should be solved
