To use the service CONFIGURATION - SPEECH VOICES of MB STUDIO PRO you need to obtain an API KEY from your desired provider.
To use ElevenLabs:
✅ 1. Open the ElevenLabs website
Go to: https://elevenlabs.io
✅ 2. Sign in or create a new account
Click “Sign in”.
If you already have an account, enter your email and password.
If you don’t have an account, click “Sign up” and create one (it only takes a few seconds).
✅ 3. You will arrive on the Dashboard
After signing in, you are on the main page of your ElevenLabs account.
✅ 4. Go to the “API Keys” section
In the top‑right corner, click your profile icon.
In the menu that appears, select “API Keys”. (On some accounts, this section may also appear in the left menu.)
✅ 5. Create a new API Key
Click “Create API Key”.
Give the key a name (e.g., “MBStudio”).
Confirm.
✅ 6. Copy your API Key
ElevenLabs shows the key right after it is created.
Click “Copy” and then paste the key in MB STUDIO - Configuration - Speech voices - ElevenLabs
Keep it in a safe place and send it only to your technician.
❗ Important
The API key is a “technical password” that allows your software to use ElevenLabs voices.
