To use the CONFIGURATION - SPEECH VOICES services of MB STUDIO PRO you need to obtain an API KEY from the desired provider.
To use Inworld:
✅ 1. Open the Inworld website
Go to: https://inworld.ai
✅ 2. Sign in or create a new account
  • Click “Sign in”.
  • If you already have an account, enter your email and password.
  • If you don’t have an account, click “Sign up” and create one (it only takes a few seconds).
✅ 3. You will arrive on the Dashboard
After signing in, you are on the main page of your Inworld account.
✅ 4. Go to the “API Keys” section
  • In the top‑right corner, click your profile icon.
  • In the menu that appears, select “API Keys”. (In some versions, it may appear under Account Settings.)
✅ 5. Create a new API Key
  • Click “Create API Key”.
  • Give the key a name (e.g., “MBStudio”).
  • Confirm.
✅ 6. Copy your API Key
  • Inworld shows the key immediately after creation.
  • Click “Copy” and paste it in MB STUDIO - Configuration - Speech voices  - Inworld
  • Keep it in a safe place and send it only to your technician.
