The "Speech" object allows you to insert text into playlists, minilists, or time sequences, which will be transformed into a speech voice shortly before broadcast. The text can be written directly in the "Sentence to read" field (maximum length 260 characters), or in the "File to read" field, you can upload a .txt text file with a maximum length of 2,000 characters. All MB STUDIO wildcards can be used in the text. WILDCARDS LIST
Voice Name: This selector selects the synthetic voice. If you select "Random synthetic voice," MB STUDIO will randomly select a voice with the specified gender.
Style: This selector affects the style and speed of the synthetic voice and has different effects depending on the provider. Quality only affects ElevenLabs and is irrelevant for other providers. Stability and speed affect all providers.
Save as: Generates the synthetic voice in an MP3 file of your choice
Prelisten: Generates the synthetic voice on the prelisten
Apply: Inserts the text into a playlist or timeline.
Synthetic voice is only available in MB STUDIO PRO and MB REMOTE and can only work after configuring at least one provider: CONFIGURATION - SPEECH VOICES
For ElevenLabs, the 3 quality levels have the following meanings:
- standard = uses the "eleven_turbo_v2_5" model, basic quality and very fast data transfer
- good = uses the "eleven_multilingual_v2" model, very good quality but slower download times
- pro = "eleven_v3" the best quality but download times are quite slow
