The synthetic voice feature in MB STUDIO PRO now supports the prompt: command.
With prompt:, you can send instructions to the AI to generate text, which will then be rendered using the synthetic voice.
To use this feature, the ASK THE AI service must be active
In your commands, you can use MB STUDIO wildcards: https://www.mbradio.it/en/support/help/119-wildcards
In the "phrase to read" box, type "prompt:" followed by an explanation of what you want the AI to do or what you would like it to achieve.
Example:
prompt:announce the end of the song %sa-1% and introduce the song that is beginning %sa% all within about 60 seconds. If you have any interesting facts or news about the songs or the artists, feel free to share them.
For a more personalized result, you can also configure the "Prompt instructions:" section, found under Configuration / AI. Here, you can enter instructions that will apply to all announcements, so you don't have to repeat them for every individual prompt.
