It's important to define some default folders where MB STUDIO will save files.
In this section, we can configure the default folder for songs and random files in MB STUDIO and MB REMOTE, and for advertisements and news in MB SPOT and MB SPOT REMOTE.
- Copy files to default folder - imported files are simultaneously copied to the specified default folder.
- Move files to default folder - imported files are copied to the specified default folder and then deleted from their original location.
If neither of the two options is active, the files remain in their original location and MB STUDIO will add the source folder to the list of folders in CONFIGURATION - FOLDERS
It is recommended to enable the "move" option (this will avoid having duplicate files on your computer).
It is also recommended to keep all the songs in a single folder (without subfolders).
